Need help here.
Old Jan 23, 2002 | 07:26 PM
icav's Avatar
On a stock 400EX when you buy it from a dealership is it already filled with oil,brake fluid, chain lubricated ect ect? How often do you oil your chain and put oil in the quad? How often do you put in brake fluid?
icav
Old Jan 23, 2002 | 10:55 PM
KILLER250R's Avatar
Of course it comes with all that.[img]i/expressions/face-icon-small-confused.gif[/img]
You should change the oil atleast once a month, and brake fluid whenever it goes below the full mark. The Chain should be lubed after every ride or so.
Old Jan 25, 2002 | 08:27 PM
hondaquadrider's Avatar
yeah it will come with all that, i always change mine about every 3 months in my 400EX, but there is a certain way u have to change the oil, u have to fill it up, ride it for about 10 minutes and check it and if its low put some in it, thats what they told me to do on mine..
Old Jan 26, 2002 | 11:33 PM
icav's Avatar
Does a quad have transmission fluid??
Old Jan 26, 2002 | 11:53 PM
Mr350X's Avatar
The same oil lubes the tranny, clutch and engine.
-Matt
Old Jan 27, 2002 | 12:02 AM
Alien01's Avatar
MAKE SURE WHEN CHECKING THE OIL YOU LEAVE IT UNSCREWD . JUST PUT THE DIPSTICK IN AND PULL IT OPUT DON'T THREAD THE THREADS.
Old Jan 27, 2002 | 05:40 PM
icav's Avatar
Do you actually "change" your oil??? Or just put more in??
icav
Old Jan 28, 2002 | 12:20 AM
dunechick's Avatar
yes, change it! the general idea here is to take out old dirty oil and replace with fresh new oil...
look in the book they gave you with the quad. the info should be there. change the oil filter at the same time. you will need a set of Metric sockets or wrenches.
it's pretty easy, drain oil (2 places! - see book), replace those bolts, take out oil filter put in new (do not lose the spring inside there), replace cover and bolts, put petroleum based oil back in for now since the quad is still new. You can use synthetic later when the motor is broken in/seated.
need to clean and oil your air filter too. At the Honda dealer you can pick up a kit that has air filter cleaner and spray oil for about $15. the air filter is under your seat. know how to get to it? if you ride in dusty areas clean it more often. I usually ride sand and mine stays pretty clean.
flyin-lowe
Dec 1, 2017 03:18 AM
salixair
Nov 3, 2015 08:25 AM
bvandass
Oct 8, 2015 09:13 AM
YankeeRebel
Oct 6, 2015 06:44 AM
cboler9
Sep 24, 2015 08:35 PM
