spark knocking lt500
Old Jan 24, 2002 | 09:42 PM
zillarider's Avatar
hi i have an 87 lt 500 that runs great except for real bad spark knock when the powerband kicks in,i run golden spec with 93 octane gas. is there some type of timing that could be off and how could i fix it ? Thanks Brandon my email is dirtdogz@1010internet.com
Old Jan 25, 2002 | 10:11 AM
Backcountry's Avatar
Timing usually doesnt slip...if it does then that means the flywheel key has sheared and the engine will either run roughly or not at all.
Carbon build up on the piston can cause an increase in compression that would possibly create some pinging. Check you compression with a quality thread in style gauge(Snap-on is the best). If its abnormally high for a stock engine, you may need to tear it down and remove the carbon from the piston crown.
Coolant mixing with the fuel-air charge will also reduce the octane the level, increase the compression from the steam, and ultimately create pinging or worse detonation. Head gasket leak, known to be a problem with the lt5's. Using coolant???
Lean jetting can cause pinging and detonation. The increased heat created from lean jetting does this. Verify you are jetted right across the board.
Old gas??? Wrong mix ratio???
Old Jan 25, 2002 | 10:35 AM
biggy's Avatar
great post
could also be sloppy piston (skirt rap) or a rod ?
fordfaithful21
Dec 7, 2015 05:52 PM
Slagpolaris
Sep 5, 2015 09:41 PM
Jason Richards
Sep 4, 2015 06:17 PM
jeff mc
Dunes and Dune Machines
Sep 3, 2015 07:47 PM
vtech
Help With Forum Software!
Sep 2, 2015 05:59 PM
