Head pipe insulation.....automotive header wrap?
Old Jan 25, 2002 | 09:25 PM
ProEMTPFF's Avatar
I was thumbing through a older JEG's catalog and saw some insulated "wrap" for headers. Does anyone know if this would work on our head pipes to help with the heat build up that is in part killing the radator fans? Would it in any way cause a power loss or hurt the head pipes? Eli54 "Elliott" I have the RWR exhaust will this hurt the finish or performance any? I'm going to call JEG's on Monday and get a new catalog and see if this "wrap" is still available.
Old Jan 27, 2002 | 12:10 AM
AZSAND's Avatar
THAT!!!!!Sounds down right sexy!
Hey pro the rap is fine i had it on mine for a while and i had the ron woods exhaust.but when i changed to the graydon i just threw away the fan my problems were solved and at glamis i noticed vegas was not running a fan either.and we both live in hot climates as you do so good luck.
Old Jan 27, 2002 | 12:19 AM
ProEMTPFF's Avatar
I've had the broken fan all winter and I have'nt had a problem yet BUT I know this summer with the humidity we have here in Florida I'll be needing the fan again. Last summer the fan ran alot and I do ride trails so like I said before the fan will be needed again soon.
Old Jan 27, 2002 | 12:30 AM
AZSAND's Avatar
Well pro taking into account the humidity i dont think wrap would work for you any way due to corossion.we don't have that problem. remember arizona it's a dry heat
Old Jan 27, 2002 | 08:18 PM
Crashfirepm53's Avatar
When i replaced my fan , i bought it from what he told me was the #1 distributor for the fans. Any ways although these fans do have automotive applications, the majority of them are designed and used for major medical cooling systems in hosp. equipment.obviously there is no vibration there.thats why spal WILL NOT warranty your fan if they know what it's used for.Also me and my brother have the same setup on our DS's and his fan comes on all the time where mine comes on alot less.Any reason for that??
PS mine is WAY faster than his!!!!Only diff is my 22'' Razors or taller than his 22'' holeshots. sorry bro
Old Jan 27, 2002 | 09:53 PM
jeffnrivercity's Avatar
ProEMTPFF,
I use the header wrap on my Graydon pipe,but for a different reason.My pipe is close to the dual carbs so I use it to keep the heat off the carbs,plus it also keeps the heat off my leg.It's not very pretty though,tends to absorb,dirt,grease,oil,etc.
Jeff
Old Jan 28, 2002 | 12:00 AM
ProEMTPFF's Avatar
MarkyNark, what new fan are you talking about and where can I get one?
Old Jan 28, 2002 | 12:16 AM
ProEMTPFF's Avatar
Is the fan you sell the same brand "Spal" as the stock? I know that http://www.offroadwarehouse.com has the replacement Spal for $71.99.
Old Jan 28, 2002 | 01:14 AM
BlackHawk's Avatar
Isn't there some sort of steel woven fabric like thing for automotive exhaust applications like this? As I recall it'd have a similar look to a steel woven brake line, just bigger (duh.) I seem to remember something like this wrapped around various things under the hood of various automobiles. As long as I'm not going nuts, and this really does exist, then that would look A LOT better than wrapping that tape around the headers.
ltzbrad
Sep 25, 2015 05:52 PM
greg86hd
Sep 16, 2015 12:32 AM
bvolks
Sep 13, 2015 12:57 PM
Bigtwin700
Sep 9, 2015 09:32 AM
toonces
Sep 5, 2015 01:14 PM
