pro circuit pipe jetting
Old Jan 25, 2002 | 10:16 PM
ftwflh's Avatar
We are putting a pro circuit pipe on a 2002 400ex and would like to know what jet size would work with stock air filter and air box.And Later what would be best with a K&N filter
Old Jan 25, 2002 | 10:45 PM
quad1man's Avatar
I have a Pro Cicuit T4 with a K&N and no air box lid. I am at a 158 Keihn main jet. Your elevation of 158 ft. is close enough to mine to where that may work as a starting point. With a stock foam filter and an airbox lid, I would guess a 152 as a good starting point fo you.
Good Luck.
Old Jan 26, 2002 | 09:54 AM
MagnumMudMan's Avatar
ftwflh
With the same set up as you, I am running a 155 main jet and no other changes and it runs great. I may modify the airbox this year and change the pilot jet, but with the stock filter and airbox, it wasn't necessary.
ReconBayou
Oct 31, 2022 05:37 PM
mrtidy
Feb 3, 2016 05:00 PM
Sw00p
Sep 24, 2015 02:50 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
