Back from a test ride w/mods.
Old Jan 27, 2002 | 04:32 PM
Batoutahell's Avatar
I just got back from a test ride with the baja and the new mods, big gun exhaust and dynojet jet kit.
I am still running the stock air filter setup.
I jetted a little on the rich side, because I ride a lot in the lower altitude.
At first I thought it was ok, and it ran good, but the low end power was still missing, so I stopped and pulled the airbox lid off.
It came alive. The bike pulls good all the way through the rpm range. I planned to take the lid off up here anyway, because of the richer jetting. Then I can run down at lower altitudes with the lid in place.
Anyway, I like it and it runs real good. The only problem I notice is that I am constantly bouncing off the rev limiter. I need to get one of those bad. I am kind of waiting to get one already setup for the baja, so I can just plug and play, but I may buy one sooner and rig it up myself.
Only other thing I notice is that when I let off the throttle sometimes I hear a pop, not everytime and it is usually only like 2 pops. I notice the same thing with my raptor and I think the idle circuit might be a little lean. What do you guys think?
Thanks
Bat
Old Jan 27, 2002 | 05:33 PM
ScoobyDFW's Avatar
check for any air leaks at the header pipes.
pilot will be too lean. adjust screw under carb and/or increase pilot jet.
Old Jan 27, 2002 | 07:02 PM
scooby, thanks for the reply.
I think I might have a little air leak around the header pipe. I am going to put a little high temp silicone around it and see if that helps. I am not too concerned with it. My raptor has done it since I installed the big gun and no problems. I think it is a small leak near the header pipe in it also.
Also, the mixture screw, I set it as dynotjet said, but I think it was about 3 turns out from the factory. So, I think it is a little on the lean side.
Otherwise it runs great and I really like it.
Bat
MikeyBoyesq
Nov 27, 2020 02:44 PM
TegraQuad
1) Engine problems..
13
Nov 26, 2017 01:40 PM
Smokinthebear
May 7, 2000 08:01 PM
sqooze
Mar 16, 2000 12:59 PM
hot_shoe_cv
Oct 13, 1999 02:16 PM
