Blaster throttle probs.
Old Jan 29, 2002 | 03:23 PM
BomBanshee's Avatar
Ok I bought this old Blaster as a project quad and it needs some cosmetic work but the problem with the throttle is that it doesnt respond well at all when I try to rev the engine up it hesitates before gaining any rpm's and when I let off the throttle it hesitates before returning to a idle ive inspected the throttle valve and it works and returns fine and the carb is a Keihin. Thanks for any help.
Old Jan 29, 2002 | 04:47 PM
THEMOOSE's Avatar
sounds like a vacuum leak. does it idle rough? spray some WD40 around the connections while at idle if the revs drop off it's a vac leak. look for cracked boots or mis aligned boots. good luck. I was thinking since it is an "old" blaster check the reeds if they are cracked it could cause throttle problems too I think.
Old Jan 29, 2002 | 08:21 PM
yamahagye's Avatar
It could also be jetted wrong.
JaMeS
2quiker
Mar 22, 2022 08:36 PM
MeadowlarkFarm
Nov 27, 2019 08:40 PM
nastyblaster100
Sep 13, 2015 01:19 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
MeadowlarkFarm
Sep 9, 2015 03:08 AM
