(knutz have u seen this before )
i was out riding this weekend when i started to shoot the sh@t with some guy .. he ask me if i had any problems with the steering stem ..(i not sure if he said steering stem ).he was saying the part on the front end of the ds which stops u from turning the wheels total around was braking .he said he works on atv,s and every ds he has come arcoss has had some damage to this part .. as he showed me on mine .i see that part starting to bend . u can see the part stressing and that metal nub which stops u from twisting your bars allaway around is starting to bend . he said once that part brakes. u lose all control .one person he spoke with said that the hole stem cam out ... i knowe this is a very vag example .. but thats the best way i know how to explain it .. knutz have u came across any thing like this ????
I bent the steering tab on my old stem,have a Diamd G anti-vibe stem now.
But I bent my original by hitting a rock at 35mph in full slide,It was all yard sale after that!I thought it held up pretty good,better then I did.
I noticed on the new Baja there is a large thick washer(I mean large)on the bottom of the steering stem that wont let the stem pull out, unless you get hit by a Mack truck.My 2000 Ds just has a small washer.The 2 piece stamped metal housing that holds the bottom stem bearing in place could be the weak link.
Jeff
Jeff
you are the weakest link ..good bye ..lol.... ok thats what i was talking about i didn,t know how to explain it .. i have a 2000 ds and i see the The 2 piece stamped metal housing that holds the bottom stem bearing in place is starting to stress .. where can i get one of these Diamd G anti-vibe stem .. thanks for the info jeff i want to get this fixed before it brakes and i kill my self ....lol
has any one else had this happen or see it starting to happen ..
I dont think the Diamond G steering stem will fix the problem,(but it is an awesome unit)If this is truly a major problem.Maybe up grading to the large washer from the Baja might be the only solution for now(to stop it from possibly pulling out)I dont have my Baja close to me right now or I would take a closer look,But the bearing plates might be stronger on the Baja.As far as bending or stressing the steering stops,I would think you would have to be pretty hard on them before you would have to worry about any failure.
Jeff
P.S. I did notice a little warpage in my bearing plates
Diamond G racing
Jeff
Diamond G racing
yea thats the tab im talking about .. the thing is that once that tab breaks the hole stem spins and it brakes the bolts that hold the stem in place ....
Hi guys
If their is a need for beefing up the steering stem tabs we can certainly do it. We add a small amount of reinforcement now but this is the first I have heard of a problem bending the tabs. We are here to take care of you and will look into it as soon as possible, we do have several irons in the fire so bear with me. Our new nerf bars are almost ready and the aluminum subframe is out for structural testing
now.
Bearman
now.
Bearman
