Compression Numbers on 86 250r
Old Feb 2, 2002 | 01:00 PM
honda205X's Avatar
What kind of compression numbers should a 86 250r be running? how about after a rebuild? And around what numbers should i start considering a rebuild?
thanks
Old Feb 3, 2002 | 02:07 AM
honda205X's Avatar
NO ONE KNOWS???????
can i get some numbers please!?
thanks
Old Feb 3, 2002 | 11:17 AM
Dill's Avatar
depends on your elevation and mods done to the motor. a bone stock motor should run around 150-160 PSI on a fresh motor. Sometimes more, sometimes less, like I said it depends on your elevation.
Old Feb 3, 2002 | 12:04 PM
honda205X's Avatar
this is a bone stock motor that hasn't been rebuilt in some time. i live in ohio..about 800-1000 ft above sea level.
thanks for the numbers!
Old Feb 3, 2002 | 01:53 PM
Sandgod's Avatar
They're running around 150-155 here at 4500ft......
Old Feb 4, 2002 | 01:57 AM
bLaStEr1435's Avatar
I have 165 psi at sea level. Mine is also still on the original bore and piston.
Old Feb 4, 2002 | 05:37 PM
retro's Avatar
One thing to remember is that not all compression gauges will give you the same reading.
I just use mine to get an idea on how much compression I am loosing between rebuilds.
As soon as I see compression start to drop 10-15 psi, I rering/rebuild.
ERIC
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
Alex Rodak
Sep 11, 2015 11:42 PM
Steeldon
Sep 9, 2015 09:38 AM
