Who Has Done The XR500 Conversion On The ATC350X Engine??
Old Feb 6, 2002 | 12:58 AM
KNOWSALOT's Avatar
The Facility
Need some help here. I have never done this but know that it has been done over the years.
When installing the cylinder and head from the XR500 on to the 350X engine,..what was done as far as modifications to the crankcase is concerned?? Did the stud pattern from the 350X crankcase line up with the XR500 cylinder??
I haven't found one of these engines already apart yet,..so I have no way of knowing unless some of you guys have already tried it.
F.Y.I.,,,This engine is going to be put into a 1992 TRX250X frame.
Thanks for any input.
KNOWSALOT
Old Feb 6, 2002 | 05:26 PM
MEANGREENMACHINE's Avatar
I haven't seen that done before. There is a guy on another website that is doing the 350x, xr500 motor conversion to his trike. He shows pics of the motor, frame, and other parts he had to fabricate to get it to fit. This might not help you but he might know how to help you. His name is HondaAtc. The website is www.threewheelerworld.com. Check it out. His section is under restoring.
Old Feb 6, 2002 | 08:52 PM
Keenan's Avatar
I've read an old DirtWheels where a XR500 head was installed on the 350X cylinder but then the cylinder was bored out to 450cc. It did not say what had to be done, if anything, for the XR head to work. I believe it was Four Stroke Tech. You might try calling them and ask some questions.
Old Feb 7, 2002 | 12:31 AM
KNOWSALOT's Avatar
The Facility
Thanks for the help guys. While I would like to use the cylinder to get some extra cc's if it works,....the head is what I'm really trying to get swapped. Why Honda never put the RFVC head on the 350X,300EX,etc...is beyond me. Anyways, thanks again.
KNOWSALOT
Old Feb 7, 2002 | 09:17 AM
jmc's Avatar
jmc
I have done the head conversion.Its not a RFVC head you use.Its an FT500 head.With a 6mm stroker and 92mm resleeve in the std cylinder you get real close to 500cc.I will post more info about the conversion tomorrow.
Old Feb 7, 2002 | 09:38 PM
KNOWSALOT's Avatar
The Facility
Thanks for the correction in the cylinder head design. I've been looking high and low for something I don't need. LOL.
Thanks in advance for any further info.
KNOWSALOT
Old Nov 8, 2003 | 05:13 PM
motoman1012002's Avatar
Default Who Has Done The XR500 Conversion On The ATC350X Engine??
hey can you tell me more about the conversion you did with the ft500 and 350x motor im wanted to d o it but i dont know if it will work. can you email me some pics or email and tell me what parts are need to do it. motoman1012002@yahoo.com
Old Nov 8, 2003 | 08:46 PM
whatwasthat's Avatar
wow, for a second there, i almost thought knowsalot was back on the forums........
Old Nov 8, 2003 | 10:53 PM
CatCrap's Avatar
Has anyone installed a 92mm Je piston in a 350x before and ran a 400ex carb? Need jet settings!!
jeepwheelin02
1) Engine problems..
Jul 18, 2020 06:42 PM
Nazz26
Jul 30, 2015 11:51 AM
KingDingalling
Jul 29, 2015 10:55 AM
KimSJoh
14
Jul 18, 2015 07:20 PM
toonces
Jul 11, 2015 12:01 PM
