87 250x will not fire
Is it a new plug and gapped right. If so try putting the spark plug in the covering but not screwing it into the engine. Then touch the other end of the plug (the end that screws into the engine) to something metal on the engine and then kick it or electric start (which ever you have). If it sparks then your spark plug wire is good. if it doesnt spark you might try repalcing the wire.
I would double check your connections starting from the ignition coil (the wire to the spark plug) on back to your voltage regulator to make sure they are secure and making good contact before you start replacing.
mrtidy
Feb 3, 2016 05:00 PM
IMLN
Sep 28, 2015 03:32 PM
Elkaholic
Sep 6, 2015 02:44 PM
