700 Rear Wheel Alignment
Old Feb 20, 2002 | 08:06 PM
SilverV10's Avatar
Today I had the 700 out to do a few tricks to it and noticed that my rear wheels are not aligned. When kneeling behind my machine the right side wheel is tipped in at the bottom, while the left is almost perfectly vertical. Any ideas?
Old Feb 20, 2002 | 10:41 PM
Scaryfast's Avatar
SilverV10,
Sounds like your right side wheel was in a hole. Keep in mind that with IRS ,the pivot point is at the inner-most part of the a-arm. Picture this.... if you jack up the rear of your machine right in the middle, both of the wheels will be "tipped in at the bottom". I hope this what you seen,,,, if not ,let us know what you find. Dale
MY PICS
Old Feb 20, 2002 | 11:25 PM
SilverV10's Avatar
This was observed on a paved driveway.
Old Feb 21, 2002 | 12:37 AM
McDrifter's Avatar
Could it be that one side has a stronger spring or shock?
Old Feb 21, 2002 | 12:39 AM
SilverV10's Avatar
I guess. But it is brand new with only 60 MI on it..........
Old Feb 21, 2002 | 03:25 AM
dougiedoo's Avatar
I assume you checked the spring adjustment to see if they were in the corresponding notches! Just a thought!
Old Feb 21, 2002 | 09:39 AM
walexa's Avatar
SilverV10,
Nothing to worry about. This subject also applies to the sp500, and has been mentioned in this forum before. You might be able to do a search to pull up old topics on it. Like I said, it is nothing to worry about........just a Polaris quirk.
Waylan
STLyamwar
Jul 25, 2020 04:44 AM
DFWSRT8
Aug 20, 2015 09:24 AM
mbkirk
Aug 14, 2015 08:20 PM
mbkirk
Technical and How-To Articles
Aug 14, 2015 08:12 PM
Bergmann
Aug 13, 2015 03:51 PM
