Hose Question for 2000 400 Scram 4X4?
Old Feb 22, 2002 | 09:38 PM
BayouBlaster's Avatar
I have 2 different clear plastic hoses that have managed to melt gainst the exhaust pipe. The first seems to be a vent hose off the carburator but the second one seems to start at the top of the transmission and then goes up(up to where I don't know becuase it was melted). Where is this clear hose from the tranny suppose to end? Is it a type of vent hose also and is supposed to be open ended? What is the purpose of the hose also? Please help? Thanks!
Old Feb 22, 2002 | 11:23 PM
Quadfather's Avatar
I beleive they are both vent hoses. Mine used to fit into hole on the frame, next to the airbox. If they melt closed, clip them.
Old Feb 23, 2002 | 07:47 AM
Mike Chero's Avatar
BayouBlaster,
The vent hoses from the carb should run down and the vent hoses from the transmission and counterbalancer should run up and into the frame near the airbox. If the hoses are getting burned, do what I did, run them inside of the shifter linkage rod. That should keep them away from the pipe.
Old Feb 23, 2002 | 09:27 AM
Thanks guys. I figured they were probably vent hoses but I had to be sure. I'll reroute them and fix my little problem.
Old Feb 27, 2002 | 05:27 PM
CED's Avatar
CED
Bayou blaster,I may be going to La Dunes saturday ,let me know if you can make it.Later.
SDR-II
Sep 29, 2015 01:06 AM
suzukiquadrunner1987
Aug 6, 2015 03:59 PM
WilliamBos
Jul 25, 2015 02:41 PM
ghost civic
Jul 20, 2015 12:36 PM
