New Rubicon Problem
Old Feb 23, 2002 | 01:56 PM
RubiconMan500's Avatar
Now when I am driving turning to the left or the right it makes a sound like gears are grinding, like on a shift ATV when you hit in between gears, or on a polaris when you rev it up then go to Drive or something. Any idea about what is happening here? Also when stuck it does the same sound. Think I got a lemon ATV?
Old Feb 23, 2002 | 03:14 PM
Rubi500's Avatar
I have had that sound when turning to the left but it hasnt done it for a while.
Old Feb 23, 2002 | 07:01 PM
JRM's Avatar
JRM
EEK, thats a horrific sound! Have you shift linkage checked as maybe when you turn it trys to take it out of gear or something? I dunno, but thats a major sound
Old Feb 24, 2002 | 11:08 AM
Rubi500's Avatar
I dont think that could be the problem because the Rubi doesnt actually have gears, it has a swash plate.
Old Feb 24, 2002 | 11:13 AM
thenewfiebullet's Avatar
Is it possible it's coming out of the front diff?
Old Feb 24, 2002 | 11:18 AM
Rubi500's Avatar
Yes that is a pssiblity. That is what i thought te first time i heard it.
Old Feb 24, 2002 | 04:01 PM
JRM's Avatar
JRM
actually the Rubi has alot of actual gears in the sub transmission (hi-low range) and Rubiconland had his fail on him with nasty sounds. Your right though, front diff would be more logicial.
Old Feb 24, 2002 | 07:36 PM
AtomicAustin's Avatar
How would he check the front diff. to see if its messed up?
Old Feb 24, 2002 | 07:46 PM
TEXMud's Avatar
The first thing I would do is check your front differential fluid. I would suspect with the noises you are hearing either the fluid is contaminated (water and/or mud) or there is no fluid in there.
Old Feb 24, 2002 | 09:58 PM
Hey TexMud thanx for what you just said that helps alot last week me and AtomicAustin went to his lease and went cruzin in water over the fenders. I will drain it and buy some new oil for it anyway now.
Thanx
