Best Pipe for 300EX
Old Feb 18, 2000 | 08:00 PM
Y2K300EX's Avatar
What is the best pipe for the 300EX? Is the White Brothers E-Series any good? How loud is it? Does the quite core insert help? I saw the R-Series do/are they making it for the 300EX?
Thankx
Old Feb 19, 2000 | 12:17 AM
y2kTHUMPIN300ex's Avatar
Man if you want my opinion you can't beat the SUPERTRAPP systems.They have the best of both worlds.You can run them with the discs to cut back on the noise or wide open for the most power.Even with all the discs there is a big performance upgrade over stock.I don't know about on the 300 but my friend put a white bros. pipe on his new 400ex and wasn't real impressed with the results,but don't base your decision on that.I'm sure the guys on here will give you a bunch of good input.Just remember that if you put a pipe on,you will need to also upgrade your air flow into the engine to get full benifit from your exhaust. GOOD LUCK !!!
Old Feb 19, 2000 | 08:14 PM
300ex-treme's Avatar
I have installed a Poweroll header pipe on my 94 ex and got a good bit more power. I bought this so I could retain the stock muffler as I was a security guard at a campground for about two years. I also added a K & N filter with a Moto-force (?) air box lid. After a jet change, it will tap the rev limiter in first thru fourth gears. Rides good without the noise!!!
300ex-treme
Old Feb 20, 2000 | 12:31 AM
TRAIL's Avatar
I have heard of people puttin BIG GUN exhaust one thier 400ex's and i checked it out and they also make them fora 250x/300ex.I have heard they out perform FMF.
Old Feb 24, 2000 | 09:36 PM
DG_300EX's Avatar
SUPERTRAPPE DEFINETLY
Old Feb 25, 2000 | 08:52 AM
Mike300EX-99's Avatar
I have a DG RCM pipe on mine, comes with a bigger header pipe. I have had good luck with mine, others say they suck. If you can stand the noise, it'll give your bike alot of power.
Old Feb 25, 2000 | 12:52 PM
hondatrx300ex's Avatar
I'm thinking about getting a Big Gun since they give good power and aren't as loud. When I put a aftermarket pipe on should a use a K&N filter?
97 300 ex paid only $2000 for it in good condition.
Old Feb 25, 2000 | 04:58 PM
Yes you should put on a high flow filter such as the K&N or UNI. The reason being if you put on a pipe you allow the motor to exhaust more. If you don't allow more air in you will not see any benefits from the pipe. More flow in = more flow out=MORE POWER. You probably will have to rejet your carb. I only went one up on the main, 122 to 125. Good luck!
Old Feb 26, 2000 | 07:32 PM
Y2K300EX's Avatar
Where did you get the Poweroll header pipe. How much does it cost. If you know where you got it can you tell me the phone number.
mrtidy
Feb 3, 2016 05:00 PM
ltzbrad
Sep 25, 2015 05:52 PM
Bonzhonda300ex
TheATVSuperStore
Sep 17, 2015 01:21 PM
greg86hd
Sep 16, 2015 12:32 AM
ScopeZ_
Sep 13, 2015 07:55 AM
