Gravel Driveway Grading
Old Feb 26, 2002 | 10:25 AM
Beegs's Avatar
I live on a gravel driveway that we share with two other families that is approximately 1/3 mile. Over the course of a year it needs to be graded to remove pot-holes and tire ruts. I have a Honda Foreman and would like to find a drag or other implement that will do the job vs. using a rented tractor and a landscape rake ($) . Any thoughts? My concern is finding something that has enough weight to loosen up the gravel. I would appreciate any information or ideas you might have. Thanks. Greg
Old Feb 26, 2002 | 05:25 PM
bigdawg1031's Avatar
Cabelas has an ATV Harrow Drag that can be set to dig deep (3" to 4&quot, shallow or flipped over to smooth after roughing it up. I've used mine a couple times and think it would work great on gravel driveways. It's well
built and will withstand adding weight for deeper penetration. $300.00
Old Feb 26, 2002 | 06:48 PM
RaptorRy's Avatar
I have used a piece of chain link fence with two 2x4 on the ends with I hooks and then throw a couple 4-6 cender blocks or haVE THE KIDS STAND on it it works ok and is cheap
Old Mar 3, 2002 | 01:12 AM
robbieg's Avatar
i use a 3 foot york rake with a swing down grading blade. it works real good.
Old Mar 12, 2002 | 06:43 PM
jaybeecon55's Avatar
Sound advice there. "Hey, watch this........"
Take a 4x4 or landscape timber, run it through some 8x8x16 cinder blocks, drill a hole in each end and run a chain, cable or line from each hole to your trailer hitch. does a fair jog and only costs a few bucks. Best width is about 4-6 feet.
Jaybee
Old Mar 12, 2002 | 07:02 PM
piz's Avatar
piz
A cheap and easy way is to take a old box spring add some weight and drag your driveway
phummer3210
Sep 11, 2015 03:47 PM
Ean
Aug 28, 2015 09:39 AM
Stever6368
Aug 16, 2015 07:34 PM
Dustinyoungs
Jul 24, 2015 07:18 AM
MATT BOOTH
Utility ATVs
Jul 20, 2015 05:55 PM
