300ex swing arm and rear bearings.
Old Mar 4, 2002 | 11:36 AM
02BAJA's Avatar
I am not very knowledgable when it comes to ATV's. I have a 1998 300EX and the back axle has a lot of play in it, so much to the point it will actually bind up. Do I need a new swing arm or is there some bearings that can be replaced in the swing arm housing? I guess what I am trying to ask is the swing arm and bearings all in one or is it seperate? Thanks.
Old Mar 4, 2002 | 01:27 PM
KNOWSALOT's Avatar
The Facility
The bearings are in a carrier seperate from the swingarm. Bearing failures are common on these machines. A set of bearings and seals will run you from 50 to 80 dollars, depending on where you buy them.
Wiley wolf
Sep 7, 2015 08:32 PM
bmark0610
ATC 3-Wheelers
Sep 7, 2015 07:57 PM
bmark0610
ATC 3-Wheelers
Sep 7, 2015 07:48 PM
black_thunder
Sep 7, 2015 01:24 AM
OutRacing
Technical and How-To Articles
Sep 3, 2015 07:49 AM
