i need help on the mojave
Old Mar 6, 2002 | 04:05 PM
mojavekid13's Avatar
i just bought a FMF megamax2 for my mojave should i jet the carb?or can i just leave it.i had to jet with my outher one just not sure about the FMF
Old Mar 7, 2002 | 09:11 AM
mordr's Avatar
You should ok if you were jetted good w/the Supertrapp.
Did you buy the FMF for your 87 or did you ditch the Supertrapp for it-if so-why? Just curious.
Old Mar 7, 2002 | 10:46 AM
mojaveman1's Avatar
if you dont rejet will not gain any power that is where you get more power
Old Mar 7, 2002 | 06:46 PM
mentalmojave's Avatar
Mojaveman1- Do you have k&n jets and if so what are you running for jets with the white bros pipe. I have a 130 main and my needle on the 3rd notch. I'm just wondering if I should go to the 134 main and set my needle on the second clip.
Old Mar 7, 2002 | 09:05 PM
i took the supper trap off and put that on my 87.and used the jets from the carb on my 93.i bought the FMF just to try somthing different.if i dont like it as much as the supper i will take it off and put it on my 87 which i dont drive much.
Old Mar 8, 2002 | 08:44 AM
mordr's Avatar
If you took out the jets to put in your 87, then yes, as mojaveman1 said you should rejet your 93.
Old Mar 8, 2002 | 05:44 PM
cool thank a lot guys it works about the same as the supertrapp it has alittle more bottom end to tell u the truth
Old Mar 10, 2002 | 02:26 AM
mojaveman1's Avatar
i havent got the white bros exauhst yet i live in mn so it is like a degree out now so i am down to like a 124 main i would try larger with the white bros if it works keep trying a little larger till it starts to cut out then back off one step
Mojave250A
Ask the Editor
Jul 12, 2015 09:10 PM
Mojave250A
Jul 11, 2015 10:38 AM
RidE
Oct 19, 1999 06:10 PM
dunc_n
Aug 26, 1999 09:32 PM
BlackHawk
Jul 31, 1999 01:31 AM
