HELP ! Not getting any fire.
Old Nov 18, 1999 | 12:25 AM
Storm5's Avatar
I fixed it, I don't have a neutral light and I was trying to crank it in gear.... Duh!
It cranks fine in neutral.
Can you tell I'm a newbie.... LOL
I bought a 1987 Honda TRX250 FourTrax 4 cycle used.
I took all the plastic off and steam cleaned the frame and painted it.
It will not crank ever since.
It ran good before that.
I took spark plug out and grounded it to frame while turning the engine over and I'm not getting any fire from the coil.
Does this model have any fuses other than the two up front in the small compartment?
Could it be the coil?
Thanks for any input.
[This message has been edited by Storm5 (edited 11-18-1999).]
Old Nov 18, 1999 | 11:15 PM
hot_shoe_cv's Avatar
Storm5,
Knowing nothing about your ride, I'm shooting in the dark here, but it would appear that some part of your ignition system is grounded to the frame. When you painted it that part (coil?) has lost it's ground, and you'll need to sand off a little paint where it had been before painting.
THE AZ HARD PACKER, calmiller@kachina.net
save the public land FOR you, not FROM you..join the Blue Ribbon Coalition online @ www.sharetrails.org
Old Nov 19, 1999 | 02:07 PM
spanknquad's Avatar
Storm5,
Check all your wiring connections also.There's a chance you could have pulled a wire loose from steam cleaning it.
Good luck !
Old Nov 19, 1999 | 07:00 PM
Sickman's Avatar
Hot_shoe_cv is probably right, make sure the ground is actually grounded (touching bare metal on the frame), so sand the paint off where you hook the ground to the frame.
flyin-lowe
Dec 1, 2017 03:18 AM
j.graul84
1) Engine problems..
Nov 6, 2015 08:42 AM
cornermike
Jul 30, 2015 06:37 AM
toonces
Jul 24, 2015 09:03 AM
gfl0224
Jun 27, 2015 06:52 PM
