How do you remove the baffel on a raptor muffler?
Old Mar 13, 2002 | 06:25 PM
RAPZILLA's Avatar
If I take out the baffle on my muffler(stock) do I have to rejet?
How do I take the baffle out?
Will my bike run better?
I want my bike to be loud!
THANKS!!!
Old Mar 14, 2002 | 01:07 AM
NewDSLover's Avatar
Don't know about making it run better(easier air flow = more power). Louder, yes a little. As for removing it. Can't, it's welded in place. My buddy (before buying a CT pipe) removed the end cap and drilled out a few large holes in it with a long drill bit.
Old Mar 14, 2002 | 01:59 AM
guardog's Avatar
I said the Hell with removing the baffle and bought the White Bros. "e" series. 10x better. It will really waken that sleeping giant up. I could not believe the difference. Cost was 250.00 I highly recommend it
Old Mar 14, 2002 | 04:51 PM
01Raptor660R's Avatar
The baffle is not welded to the pipe. There is a screw to undo first. The second thing that most people responded about was the fact that the baffle was actually stuck. Some used pliers to pull out some pried with screw driver. If yours is stuck be fore warned that you may screw up the end by prying it out.
Old Mar 14, 2002 | 07:52 PM
RAPZILLA's Avatar
Is it the screw on the bottom of the muffler?
And yes it is stuck. But if I keep working at it it should come loose, Rite?
Old Mar 14, 2002 | 09:16 PM
2strokeDiehard's Avatar
Taking out the end baffle will make big difference at lower RPM and increases noise by 6-8 dB. The easiest way to get it out without too much damage done is to take a pair of pliers, grab the baffle tight and hit the pliers with a hammer. This WILL hurt like heII if you hit your hand but should loose the baffle up and get it out with minimal damage, as long as the pliers don't slip much. Get ready to order a pipe as you will be wanting one after you see the difference this little change makes.
Old Mar 14, 2002 | 10:57 PM
warrior620's Avatar
If you want noise and no power gain you can take the baffle out. If you want a little noise and power gain put a ct sonic or yoshi system on it. When i got my warrior the baffle was out and people could hear me 1.5 miles away! The power sucked and you could notice the usual decelleration backfireing a lot more. The choice is yours
HYS
Aug 18, 2015 12:28 PM
GNorm
Aug 1, 2015 11:06 AM
black_thunder
Jul 26, 2015 09:23 PM
black_thunder
Jul 22, 2015 06:01 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
