WHO IS RUNNING OPEN AIRBOX OR ALUMINUM AIRBOX
I am about to push my Raptor off a cliff. I am runnin a Yoshi with Denton aluminum box and a Dynojet kit with Dynojet 175/180 mains. I let it idle for 5 minutes or so and the pipes glow red. Am I still too lean? I read that sometimes the pipes glow and that Raptors don't idle well. I just can't seem to except that, is it really normal? I am runnin stock pilots and the screws are 2 3/4 and 3 turns out. How far out can they be turned? Should I try bigger mains still? Is it my screws? At this point I do not want to ride it if it is that lean so reading the plug isn't really helping I don't think.
I know tunning is difficult and I am still a newbie but there must be someone else that is running with this type of airbox and pipe.
Thanks for everyone's help!
Keep turning the mixture screws out 1/4 turn at a time. If you reach 4 complete turns out and it still runs lean (pipes glowing red) go up a size or 2 on the pilot jets and start over. Once you get the lean condition solved your Idle will become more stable, then adjust to the high side of the RPM range which I believe is 1550 RPM's. Your lean condition will only be corrected (at Idle) by adjusting the mixture screw.
First of all you are entirely too Rich on your mains. I would say that I am pushing rich at 160/165 Dynojet with the 686. You should be perfect at 148/150 on the mains, aluminum airbox or not. wshrdskin has it right on the airscrew. I have heard if you have to go past 3 turns out you should go up one size, pilots go 22.5(Stock), 25, 27.5, etc.
I HAVE THE SAME SET UP ONLY THING DIFFERENT IS I USE CT TITANIUM NEEDLES AND MIKUNI JETS (BUY FROM ANY ATV MOTERCYCLE SHOP)
162.5/167.5; PIOLT JET 25 AIR SCREW 2 3/4 TURNS OUT AT SEA LEVEL
GO TO THIS WEB PAGE:
www.users.qwest.net/~tcamp30/jets.htm
IT EXPLANES THE DIFFRENCE IN JEST BETWEEN MIKUNI VS DYNOJET ALSO WHAT
THE NUMBERS MEAN ON THE JETS REAL GOOD IMFO .
MY CLEAR UP WHE DEAL WHEN FOLKS STATE WHAT JET SIZES THEY ARE USING
A 160 MIKUNI IS ABOUT ATHE SAME SIZE AS A 170.7 DYNOJET OR EQUAL TOO
HOPE THIS WILL HELP
STEVE
ALSO HAVE THE PRO DESIGN ADAPTER PLATE WITH K&N FILTER AND OUTERWARES
HOPE THIS WILL HELP
STEVE
MIKUNI HAVE A COUNTER SUNK LEAD TO THE TOP SIDE OF THE JET OPPSITE END OF THE THREADS
DYNOJETS ARE A STRAIGHT HOLE NO TAPER LEAD
HOPE THIS HELPS STEVE
FORGET TO YET YOU KNOW
THE CT TITANIUM NEEDLES LET MORE FUEL THOUGH THE JETS THAN STOCK
NEEDLES CT NEEDLED ARE SMALLER IN DIA. ( ON A TAPER OF COURSE)
SO I CAN USE A SMALLER JET SIZE IF USING A STOCK NEEDLE
MAY HAVE TO GO TO LARGER SIZE JET OR MOVE THE POS. OF THE
NEEDLE CLIP TO NUMBER 4 OR LOWER TO LET MORE FUEL IN
GO NOT TO BE ON THE LEAN SIDE
