Compression test - Raptor
Old Mar 14, 2002 | 10:11 AM
FISHER1648's Avatar
I do not have a service manual - yet. Please bear with me.
Does the Raptor have an automatic compression release ? Some kind of cetrifugal deal that dis-engages when the RPMs come up. If so, how do you do a simple compression check ?
Old Mar 14, 2002 | 11:00 AM
FISHER1648's Avatar
oops - let me clarify. I have the tester and use it often on other engines but heard somewhere that the Raptor has an auto compression release. I'm guessing the compression should be in the 120 psi ballpark - correct ?
Old Mar 14, 2002 | 11:33 AM
garyc660R's Avatar
Yes the Raptor has an automatic compression release. So unless this is disabled, you are gonna get false readings.
Old Mar 14, 2002 | 11:36 AM
SandRaptor's Avatar
The raptor does have a auto compression release. I just put my bike back together a couple of weeks ago Trinity(686 Kit). So you would have to take the entire valve cover off and pin the weights to their outer most position. Reinstall the valve cover, it holds the cam in place, and then do yor compression check.
SandRaptor
Old Mar 14, 2002 | 11:40 AM
garyc660R's Avatar
How do you like your 686 kit? Was service prompt?
slowgsxr97
Mar 18, 2022 03:40 AM
Big bousse
Sep 26, 2015 10:42 AM
Hankey Pankey
Jul 31, 2015 05:50 PM
Hankey Pankey
Technical and How-To Articles
Jul 29, 2015 10:57 PM
southbayman
Jul 24, 2015 09:30 AM
