major wolverine help
Old Feb 23, 2000 | 12:02 AM
wolverine_4x4's Avatar
i have a 95 wolverine and i go to crank it to warmit up it does it fine then i kill it go back out to crank it agian to ride it and the engine one even turn onver and the battery is good the neutral light is on bright and the headlights are on so what could it be?if u know what it might be and knonw the price please tell me
thanx
Old Feb 23, 2000 | 02:40 AM
Tree Farmer's Avatar
Kill switch?
Loose starter solenoid connection? (Sometimes, wires/connectors shake loose from jumping or crossing rough terrain.)
Nest step; trace wires with help of wiring diagram from manual, or make your own as you go.
Good luck!
Tree Farmer
Old Feb 23, 2000 | 02:42 AM
boomer's Avatar
I would check the starter switch first, make sure there are no shorts or exposed wires. If thats OK, then I would make sure that when the button is pushed, power is getting to the starter. If it is, the contacts in the starter could be bad. Like a solenoid in a car that engages the starter. Hope this helps.
Old Feb 23, 2000 | 03:25 PM
Mud_Runner's Avatar
There are two white relays mounted in a rubber holder on the frame under the left rear fender just forward of the battery box. They can crack, and get moisture in them causing intermittent starting problems like you describe. Put your hand on them as you push the start button, you should feel a definate click. If it is intermittent, try tapping on them while pushing the button. If this gets it to turn over, that is your problem and that relay needs to be replaced.
This happened to me and it took along time to troubleshoot. Good Luck!
bmxatv10
Oct 14, 2022 06:23 PM
suzuki230
Jul 8, 2016 10:03 AM
Atvnewb88
Aug 19, 2015 02:22 AM
Atvnewb88
Aug 13, 2015 06:48 AM
Nelson
Jun 20, 2015 01:59 PM
