Trinity 686 owners- what pipe?
Old Mar 20, 2002 | 10:42 PM
14mins's Avatar
I was wondering what pipe you are using and what pipes you have tried. I am using my gyrt slip-on. Raptor720 cleaned up my head pipe. I am in no real hurry to change, this 686 rips the way i have it set up now. Thanks
Old Mar 21, 2002 | 12:07 AM
SandRaptor's Avatar
I'm running a full HMF system, used to run the stock headpipe with a R Series muffler. So what did you end up at on your jetting? I am currently running dynojet neddles and mikuni 165/170 jets at 3500ft alt. Harry wants me to put the stock neddles back in and run a 180/187.
On the runs that you used to pull second gear on when stock, what gear can you pull now with your 686.
I was expecting that sense I had twice the hp I should be able to pull twice the gearing. Stock 2nd, 686 4th, doesn't seem to hold true. Maybe I am expecting to much.
Old Mar 21, 2002 | 12:25 AM
SykoQuadRider's Avatar
The HMF system is not that good. I did not like my system at all. Lost to much on top and didnt gain enough on bottom. Hopefully the CT is better.
Old Mar 21, 2002 | 12:38 AM
Xplor's Avatar
Syko... explain about the HMF system. I have the full system and definately noticed more power last season. Compared to the guys I was running with I had gained power and speed but... Just took her out for a ride last week against a new "stock" 2002 Raptor and I got spanked! He got me from 1rst gear on up and had a couple MPH more on top!
I am stumped on this one.
Old Mar 21, 2002 | 12:45 AM
When I had the HMF with filter and jetting I would pull out in front until about third gear against a stock raptor then he would pull up and past me and leave me by a few bikes. The pipe is good for low end for on a MX track but you lose too much top.
Old Mar 21, 2002 | 01:34 AM
14mins's Avatar
Sandraptor- I have dynojet needles and stock jets. Changed to stock needles and 180, 187.5 needle clip in the 4th, fuel/air 2 3/4. WHAT A DIFFERENCE. Change those needles or get larger dyno jet jets. I got it to run good on the combo, but you will find a Big improvent changing.
mrtidy
Feb 3, 2016 05:00 PM
ltzbrad
Sep 25, 2015 05:52 PM
XxS0ccerstarxX
Sep 22, 2015 08:07 AM
greg86hd
Sep 16, 2015 12:32 AM
bvolks
Sep 13, 2015 12:57 PM
