quick question
Old Mar 22, 2002 | 10:38 AM
shmoky's Avatar
What does the "Book" say for the time allotted for a mechanic to do all the brakes on a 2001 auto.
shmoky
Old Mar 22, 2002 | 08:49 PM
dakotart's Avatar
I don't know what it says but this shadetree mechanic can do an 01 500 manual and a 400 in one afternoon with only a 6 pack of beer and about 4 tools.
Dakota R/T
Old Mar 22, 2002 | 10:42 PM
IowaBob's Avatar
Dakotart,
I'm very disappointed in your performance. It should only take half the afternoon and a 12 pack in order to be done correctly.
Bob
Old Mar 23, 2002 | 01:31 AM
shmoky's Avatar
Thanx for the replies. I left mine machine at the dealer and the back brake was totally gone. [img]i/expressions/face-icon-small-sad.gif[/img] (no wonder I had no braking) the fronts were at 50%. I will do them myself next time. I hve 986 mi. on and this is what my brakes are at. They will charge me 2hrs. labor for checking the brakes, replacing the back pads and bleeding all the lines. I felt this is to much, is it?
shmoky
Old Mar 23, 2002 | 10:12 AM
dakotart's Avatar
To be honest with you that is about the time it took me to do one of my quads. But I imagine with parts and labor you are looking at a $250 job if I had to guess. I think the cat pads are over priced at around $30 a set down here. I used the EBC pads for $22 a set and have had good results.
IOWABOB,
I'm working on improving my performance, I'll be doing some "12 oz. curls" by my pool tonight!
Dakota R/T
Old Mar 23, 2002 | 09:13 PM
IowaBob's Avatar
dakotart,
Glad to here you're working on your problem! Those "12 oz. curls" can be very difficult, especially by the pool! If you need some help with the finer points of the art, let me know.
Bob
Old Mar 24, 2002 | 11:42 AM
Bigdcred's Avatar
shmoky
It takes me less then 1 hour to do all 4 sets, put the bike in the air take all 4 tires off, there are 2 bolts on the back of the brakes (10 mm) undo them, DON'T undo the brake lines, lift up the brake cylinder undo the safety clip pull the pin and the brakes fall off into your hand, if you haven't done any damage to the rooter just give them a light sanding, use some Chanel locks to squeeze the plunger back into place(this is easer if you loosen the top 2 screws on the brake fluid bowl on the handle bar), then revers the proses to put it back together, DON'T forget to tighten the 2 screws on the brake fluid bowl, squeeze the brake a couple of times it should tighten right up. good luck you just saved your self over 150 bucks by doing it your self.[img]i/expressions/face-icon-small-happy.gif[/img]
cornermike
Sep 10, 2015 08:30 AM
Albertaboyy
Sep 9, 2015 09:51 AM
Rooky
Sep 9, 2015 03:16 AM
MikeyBoyesq
Sep 7, 2015 10:44 PM
Logan Collins
Sep 5, 2015 08:03 PM
