pipe for 83 200x...help?!?!
Old Mar 23, 2002 | 07:08 PM
PismoGuy400's Avatar
does anyone know of a company that makes the best pipe for an 83 200x...i just need more hp out of the ol' thing
Old Mar 24, 2002 | 01:28 AM
mintychip's Avatar
I had a Kerker on mine and my friend had a Supertrap on his. The Kerker made the bike easier to start and was much quieter and the performance felt the same. He bought my pipe off me when I sold the bike and his notoriously hard starting 200x became much easier to start after.
If you want more power, bump up the compression with a weisco piston (10.25 or 13:1) and get a web cam, they're really cheap. Chaparral used to sell a flat slide mikuni for the bike a few years ago, but I haven't checked to see if they still do. Other than that make sure your timing is good, those bikes can handle fairly aggressive static timing advance, but they become much harder to start, which is a concern if it's your girlfriend or kid's bike.
Old Mar 24, 2002 | 01:35 AM
KNOWSALOT's Avatar
The Facility
Both DG and Cobra still make pipes for the 200X as well as SuperTrapp.
The SuperTrapp was known for the best power increase on the 200X engine but is also the most expensive pipe. The 4" Race Series runs about 275.00
The Cobra's have a much larger head pipe than the DG or the SuperTrapp and is cheaper. The aluminum silencer version only costs about 120.00
You can use the cam from a 1986-up XR200 for more mid-to-top power.
Using the '86-up XR piston will give you 10:1 compression ratio versus the stock 9.6:1 .....Wiseco also makes a piston kit with 10.25:1 compression. Use it if you want a forged piston,..and go with the Honda if you prefer cast and "factory" reliability.
Use the carburetor from the '86-up XR200. It's 26mm. The 200X was 24mm
If you use this carburetor, you will need a '80-'84XR200[Non-R] intake manifold to match the new carburetor. This one has a larger inside diameter than the 200X. Honda part# 16210-446-000 This older XR intake will allow the late model XR carburetor to mount in the stock location. The '86-up intake will not work.
I know you didn't ask for this info., but I kept notes back in the day and you said you wanted more power. Curtis Sparks still had a few hop parts left available a couple of years ago. I don't know what he has left or if he still stocks them, but you might want to give him a call. Afterall, he was the fastest 4 stroke ATC rider that ever lived.
Old Mar 24, 2002 | 04:56 PM
ok...right now money isnt a very big issue (ive got just under 500 saved up for a pipe)...i think ill be gettin the pipe from supertrapp, and knowsalot, you didnt mention anything about the dg pipe,..how does it comapre to the supertrapp..., and mintychip, this bike is going to be strictly for me to cruze around the dunes, i thinnk the piston kit would be a good idea , but just not on this shopping spree ...haha........thanks guys
travis
mrtidy
Feb 3, 2016 05:00 PM
ltzbrad
Sep 25, 2015 05:52 PM
XxS0ccerstarxX
Sep 22, 2015 08:07 AM
greg86hd
Sep 16, 2015 12:32 AM
bvolks
Sep 13, 2015 12:57 PM
