raptor jetting
Old Mar 26, 2002 | 05:32 PM
rideraptor420's Avatar
i have a raptor with white bros. e-series pipe and fmf header what jets will give me max power with that quad
Old Mar 26, 2002 | 09:57 PM
wshrdskin's Avatar
Your elevation is a critical piece of information for anyone to try and help.
Old Mar 27, 2002 | 12:23 AM
im about 4500 feet
Old Mar 27, 2002 | 12:42 AM
Sandgod's Avatar
I am at your elevation. I have a K&N filter in the stock airbox w/ ten one inch holes in the lid. 150/155 mains, stock pilots, 1&5/8 out and 2&1/4 out on air screws. Perfect!!!!!
Old Mar 27, 2002 | 11:16 AM
vraptor's Avatar
i'm at a bit higher elevation (5200' homebase ride at 7500' most of the time) and a bit more modified full exhaust no airbox lid k&n, dynojet running 146/148, 25 pilots and my air fuel at 2 3/4 out
Old Mar 27, 2002 | 01:23 PM
how do you measure how to turn the screws
Old Mar 27, 2002 | 07:18 PM
Sandgod's Avatar
My dealer did mine on an engine analyzer, then when I lost thrid gear I asked the mechanice how my jetting looked. He said by the looks of the oil ring being 1/4 inch from the top of the cylinder it looks perfect. That was a different dealer. They are looking for a certain exhaust temp and adjust your air screw accordingly. If your mains/ pilots/ needle's are to far off they can never adjust the carbs to achieve the desired exhaust temp so you must rejet accordingly.....
Old Mar 28, 2002 | 01:57 AM
mintychip's Avatar
<< how do you measure how to turn the screws >>
You count
Old Mar 28, 2002 | 10:34 AM
You count
how would you count 5/8 out?
Old Mar 28, 2002 | 10:42 AM
Sandgod's Avatar
It's betwween 1/2 and 3/4. You must be running my exact set-up or your adjusments will need to be different. The dealer will only charge you 20 bucks and then you'll always know. Of course your jetting leans out when it get cooler, but not enough on four strokes (Raptor) to warrant the hassle to change it. Two stroke you would want to rejet in the winter......
