A little off topic
Old Mar 26, 2002 | 07:24 PM
ftwflh's Avatar
I have been trying to get this old honda XR70 running.It will start and run good if you pull start it with a 4 wheeler but it wont start with the kick starter.Any ideas?
Old Mar 27, 2002 | 08:41 PM
uflg95's Avatar
How's the compression? Coast starting it will keep a constant vacum going were if the compression is slightly low a kick may not produce enough.
How about spark? It will be also be similar to the above senario.
Old Mar 27, 2002 | 08:49 PM
RickRitter's Avatar
Check the valve clearances . I suspect the intake valve is to tight.
Rick
Old Mar 27, 2002 | 09:51 PM
ftwflh's Avatar
Cold compression was 90.Plug dont fire when kicking like it couuld be a mag?But i can check the valves too it no problem on those old ones.I may try a new plug too. Thanks for the help if you think of anything else let me know.
vinrum
11
Aug 26, 2015 06:44 AM
Jkfx400P
Sport Quads
Jul 5, 2015 10:33 PM
Ask the Editor
Jun 24, 2015 10:23 AM
RedRancher
Jun 4, 2015 12:29 PM
hot_shoe_cv
Club News and Events
Dec 3, 1999 04:01 PM
