Sportman 700 Light Mod
Old Mar 29, 2002 | 01:41 AM
polrider's Avatar
I hooked up a relay that triped on all headlights on hi It works get!!!
Old Mar 29, 2002 | 09:55 AM
700guy's Avatar
polrider,
Could you please describe in detail the procedure you used? I have seen other posts on this but not in the manner you are briefly describing.
Old Mar 29, 2002 | 10:07 AM
jimcb's Avatar
yes i would like to know were you put the relay and the wiring
thank you
Old Mar 29, 2002 | 10:34 AM
polrider's Avatar
Ill try to make up a diagram tonight to post
Old Mar 29, 2002 | 01:14 PM
upnorthunter's Avatar
that would be great. I would like to do that to mine also.
Old Mar 29, 2002 | 11:27 PM
polrider's Avatar
I have to find a scanner! I have a diagram made up for ya'all.If any one needs more then this Ill work on posting it soon! I spiced into the Hi Beam (yellow) and connected one side of the relay coil and one side normally open set of contacts. the other side of contacts go to Lo Beams (green) I hooked the other side of the relay coil to accessory plug ground (brown) That way when the lights are powered on hi the relay closes powering the low beams too!
List of parts
12V relay botch or Mas
12-female spade connectors
2- good scotch connectors
wire
Old Mar 31, 2002 | 02:30 PM
700guy's Avatar
I just did the light mod yesterday on my SP700 using the diode method that has been posted on this site. All you have to do is go to Radio Shack and get two 3 amp diodes, twist them together, locate the green and yellow wires under the hood and connect them between the yellow and green wires. Make sure the power out side (stripe on diode)is connected to the green wire. Solder all of your connections and now you have all three lights on in the high beam position and just the two in the bumper when on the low beam position. This is a simple mod and takes less than 1/2 hour to accomplish. The three amp diodes cost $1.49 for a pack of two. Thanks to 500DUSE for the original post. [img]i/expressions/face-icon-small-happy.gif[/img]
Old Apr 23, 2002 | 01:48 PM
Is it possible to do the headlight mod under the headlight pod? I would think that the yellow and green wires would come from the switch?
hueby
Nov 6, 2015 11:34 AM
panicmanic
Sep 28, 2015 12:59 PM
MooseHenden
Family ATVing Photos
Sep 20, 2015 04:14 PM
Alex G.
Sep 16, 2015 12:13 PM
Steeldon
Sep 9, 2015 09:38 AM
