Red Spring on SP700
Old Mar 30, 2002 | 07:06 AM
StitchZR2's Avatar
Well I went into the dealer yesterday to get a green spring, they dint have any and they told me to go with the red spring. They said that it would be alot better out of the hole and good mid-range. So I went with it, wish I never did it, what a waste of 20bucks. It really hit hard out of the hole and mid-range was good. But it had so much wheelspin that it not get any traction. I think Im going to order the green spring. How much better is the green spring over the blue spring. Any help would be great. The reason I started to play around with the clutch spring is becasue its a little doggy out of the hole
Old Mar 30, 2002 | 07:07 AM
StitchZR2's Avatar
BTW if anyone wants to buy the red spring let me know.[img]i/expressions/face-icon-small-smile.gif[/img]
Thanks
Old Mar 30, 2002 | 07:53 AM
ftwflh's Avatar
A white spring would be good too if they had one in stock it isnt quite as hot as the green but you can tell a dif.THe green hooks up at a little higher rpm.I like it on my 2stroke but the white one is better on my 4stroke.Just a little for you to compare with.
Old Mar 31, 2002 | 02:15 PM
700guy's Avatar
I tried the green spring on my SP700 and could also not get traction due to wheel spin on dirt surfaces, although it was great on asphalt. I then went with the white spring which seems to be the best compromise.
shimanok2
Jan 29, 2016 07:37 PM
brinkkl2000
Oct 16, 2015 11:08 AM
chuck1177
Aug 11, 2015 03:22 PM
Wnthunting
Jul 9, 2015 03:02 PM
Mphillips
Jul 2, 2015 07:20 PM
