I am confused on my 400???????
Old Mar 31, 2002 | 01:32 AM
hondaquadrider's Avatar
Well my 400EX has a new stator, new plug, new cdi box, new coil, and that sucker still wont get nofire, what could be wrong with that thing, any help is appreciated.
Old Mar 31, 2002 | 01:33 AM
BLISTER's Avatar
have you checked your battery,low battery voltage will cause it not to fire.
Old Mar 31, 2002 | 01:54 AM
killerkx327's Avatar
IS THE KEY ON?
Old Mar 31, 2002 | 01:55 AM
BLISTER's Avatar
did i give him to much credit?
Old Mar 31, 2002 | 01:58 AM
d33pt's Avatar
is it getting fuel? do you have fuel in the tank?
Old Mar 31, 2002 | 02:10 AM
d33pt he said he wasn't getting any spark,not that he wasn't getting any fuel.
Old Mar 31, 2002 | 02:12 AM
ok hondaquadrider you now need to be a little more specific if you want the right answer.when you say you get no fire,does that mean no spark at the spark plug or the motor won't turn over.did you check the fuses in your battery box?
Old Mar 31, 2002 | 02:13 AM
one more item that easily over looked is your sparkplug cap,make sure it's tight.
Old Mar 31, 2002 | 02:19 AM
KNOWSALOT's Avatar
The Facility
What I find hard to believe is that you just put 700.00 worth of parts into a machine based on guessing what was wrong. Did you not diagnose the problem before ordering all of those parts? I have never heard of anyone going to those extremes without knowing what was wrong. It only takes an hour of labor at your dealer to find the problem. Then order the parts. I'm sure your dealer wasn't going to charge you 700.00 to find the problem.
OK......
When you turn your ignition key on, is the neutral light coming on when it's in neutral?? If so, does it go out when you put it in gear?? A bad neutral safety switch can cause it not to fire.
The only other common problems that can cause it not to fire [that you haven't already replaced] is a bad ignition switch, a bad kill switch, or a short[or break] in your wiring.
Because you have already dumped a fortune in parts already, I would suggest you carry it to your dealer and have them check it out for you before you spend another 700.00 on parts you don't need, and can't return being electrical parts.
Old Mar 31, 2002 | 02:34 AM
i told you knowsalot knows alot!!!!!!
