Warrior gets stuck in reverse..:(
Old Apr 1, 2002 | 11:19 AM
trackerj's Avatar
I own a 2000 Warrior an when ever it gets stuck an I have to back up, it won't come out of reverse, mostly happens when it's off chambered..Is there any way of fixing this problem ? It's really a pain when your in a tight sitation an need to get out of it in a hurry..Thank's for your help...[img]i/expressions/face-icon-small-smile.gif[/img]
Old Apr 2, 2002 | 08:39 PM
perrya's Avatar
i have the same problem with my 01 warrior. i looked back in the owners manual and it said that you are supposed to keep your foot on the brake when shifting into reverse. i have been doing that ever since and it seemed to be working.
by the way how do u like the spider tracs aren't they a little too big?
Old Apr 2, 2002 | 10:00 PM
Fendercover's Avatar
my 99 and my friends 02 also do the same thing, i found that the gears get in a bind if you don't use the rear brakes when your in an off camber situation. it seem to do the trick, have not had anymore problems since i have been doing this
Old Apr 3, 2002 | 02:03 AM
trackerj's Avatar
Well in the mud they are great, but as far as sliding goes, it's a little on the rough side..The stock tires left me stuck in every little water hole that I tried to cross..Another big draw back with them is you lose some speed because they are so flat an wide..They clean themselves out really well, end up catching alot of mud from flying over your head..
I will try the back brake trick next time I get into that situation..Thanks for the info...
[img]i/expressions/face-icon-small-happy.gif[/img]
Jackg17
Ask the Editor
Jul 16, 2018 04:01 AM
mrtidy
Feb 3, 2016 05:00 PM
Barnsnelbon
Sep 27, 2015 03:07 AM
Jackg17
Sep 26, 2015 09:30 PM
Bernhard
Sep 25, 2015 12:45 PM
