approximate Power-toWeight Ratios of all the Sport Quads !!!
please let me know if I am way off with any of my HP ratings or dry weights... I will edit this post and correct it as I get comments, if I can verify the numbers, thanks... (and NO, all of these quads were not dyno'd, especially on the same dyno) this is a compilation of different reports I have read on websites and magazines; note the word "approximate" below... so please, take this lightly, it's not meant to start a flame war
quads that are close to the same power-to-weight ratios may accelerate faster or slower, or have more or less of a top speed than what you would guess from these numbers; due to their stock gearing which is desinged around their usable power-band
__________________________________________________ ___________________
SPORT QUAD POWER-TO-WEIGHT RATIOS… Highest to Lowest
(approximate stock rear wheel horsepower / factory claimed dry weight)
1. Suzuki Quadzilla LT500 ---------> 51srwhp / 390lbs = 0.1308 horsepower per pound
2. GasGas HP 300 --------------------> 43srwhp / 386 = 0.1114 horsepower per pound
3. Cannondale Cannibal -------------> 38srwhp / 375lbs = 0.1013 horsepower per pound
4. Yamaha Banshee ------------------> 37srwhp / 386lbs = 0.0959 horsepower per pound
5. Polaris Predator -------------------> 39srwhp / 415lbs = 0.0940 horsepower per pound
6. Yamaha Raptor 660R -------------> 37srwhp / 399lbs = 0.0927 horsepower per pound
7. Bombardier DS650 ----------------> 43srwhp / 470lbs = 0.0916 horsepower per pound
8. Kawasaki Tecate 4 ----------------> 31srwhp / 339lbs = 0.0915 horsepower per pound
9. Honda 250R --------------------------> 30srwhp / 329lbs = 0.0911 horsepower per pound
10. Suzuki QuadRacer 250R --------> 29srwhp / 327lbs = 0.0887 horsepower per pound
11. Kawasaki V-Force 700--------------> 45srwhp/516lbs = 0.0872 horsepower per pound
12. Suzuki Z400 / Kawasaki KFX400-> 32srwhp / 370lbs = 0.0865 horsepower per pound
13. Honda 400EX -----------------------> 29srwhp / 374lbs = 0.0775 horsepower per pound
14. Polaris Sport 400 ------------------> 36srwhp / 481lbs = 0.0748 horsepower per pound
15. Yamaha Blaster --------------------> 19srwhp / 320lbs = 0.0594 horsepower per pound
16. Yamaha Warrior -------------------> 22srwhp / 397lbs = 0.0554 horsepower per pound
17. Polaris Scrambler 500 2WD ---> 29srwhp / 525lbs = 0.0552 horsepower per pound
18. Honda 300EX -----------------------> 17srwhp / 377lbs = 0.0451 horsepower per pound
19. Kawasaki Mojave -----------------> 17srwhp / 379lbs = 0.0449 horsepower per pound
20. Honda 250X -------------------------> 15srwhp / 351lbs = 0.0427 horsepower per pound
21. Polaris Trail Blazer ------------------> 21srwhp / 515lbs = 0.0408 horsepower per pound
22. Suzuki LT250 QuadSport ----------> 14srwhp / 370lbs = 0.0405 horsepower per pound
23. Honda 250EX -----------------------> 13srwhp / 349lbs = 0.0372 horsepower per pound
24. Kawasaki Lakota Sport ----------> 16srwhp / 448 = 0.0357 horsepower per pound
25. Suzuki QuadSport 230 ----------> 11srwhp / 309lbs = 0.0356 horsepower per pound
46HP out of a STOCK shee? Yeah right. I doubt a STOCK 250R puts out 39 HP and I'm sure that it weighs more than 329 (stock). In fact, I'm sure the Tecate and Quad Racer don't have that much stock power either and their weight is prolly a little higher as well.
If someone can prove me wrong, feel free, I can admit to being wrong. But I don't think your #'s are right.
I don't know about all of them but I think the 250r is around 365 pounds with 36.1 hp. I would have to be shown a published fact to believe that a production non-race quad weighs under 350 pounds. I also read that the C-dale Cannibal on a dyno runs between 38.5 and 40 hp. The 400ex supposedly dynos between 24.5 and 26 hp and the 250ex around 12. I would have to see it in some kind of reliable print that a stock Banshee makes that much hp at the rear wheels. Maybe at the crank but not at the rear wheels.
clymer says an 85-88 lt quadracer weighs 327 lbs. It doesnt say anything about hp ratings though. I would think around 30-32 is probably somewhat closer. The same with the stock honda 250r is probably around 30-32hp also.
actually the factory manuals for the LT250r's state the '85-86 weighing in at 298 lbs, the '87-90 is 324 lbs, and the 91-92 is 327lbs.... all dry weights. add about 25-30 lbs for full fluids, including fuel.
ok, thanks for the info guys, I'm fine-tuning the numbers as I go
I'm not changing them to reflect EVERY post, but I am weighing all the information against what I already have, as you all make comments, thanks
