Engine Question
Old Apr 3, 2002 | 06:50 PM
landking's Avatar
I have a 1990 Kawasaki 4X4 Bayou 300 cc. The engine runs fine except when engine is under no load (just driving or letting off the gas when slowing down).
Then it has a knock in it. It did not do this until now. I had it at two different dealers, and they have no idea what it is, and they are not that interested in tearing it down to find out. There is not a lot of use in this machine and should be in great shape. Is this going to blow up? Any idea what this could be?
Thanks
Land King
Old Apr 3, 2002 | 11:20 PM
nyroc's Avatar
Hard to tell w/o hearing it. I find it hard to believe a reputable dealer would not know. I test frove machines at the dealer that did exactly that.
A loose piston would probably be louder when cold and not so bad when hot, that is not what you said. I dunno, maybe it could sound like that.
I don't think the valve train could do that, does not matter about the load.
A worn rod bearing might do it, loose wrist pin bushing in rod probably would not do that.
Air cooled engines with loose head bolts make a funny dull popping sound that's louder the harder you press the gas. Does that sound familiar? You could see soot between the head and cyl.
A loose/stripped spark plug usually makes hissing sound.
Are you sure the timing isn't advanced and you are not ust getting an ignition knock? Try higher octane.
1966F100
Jul 12, 2015 03:08 AM
tporath
Jul 11, 2015 12:31 PM
toonces
Jul 11, 2015 12:01 PM
200es
Jul 10, 2015 09:09 AM
D-Hagz
Jul 4, 2015 02:19 AM
