switching from a j-arm frame to a-arm frame
Old Apr 3, 2002 | 10:24 PM
discharge's Avatar
i've got an 88 banshee with the old frame...i'm wondering what i need to make the cross over to an a-arm frame....is it even worth it...don't get me wrong its a very solid frame but i think it has to be retired because of its age
Old Apr 4, 2002 | 12:35 AM
Rudedog's Avatar
There is really nothing wrong with a J-Arm (early style) frame. Sure there not quite as strong a the A-arm style, but the difference is minimal. I had a 1989 J-Arm frame and never had a problem with it. If you frame isn't severly cracked, bent or rusted nearly into, don't bother, the frame you have will work just fine. Options if you want to change:
1) There's a company that makes a conversion kit. Buy it and weld it
in.
2) Buy an A-Arm frame 1991 (I beleive) or newer, a set of Upper A arms
and just transfer all of your parts over to the new frame.
I did number (2) myself as I found a incredible deal on a new frame.
Rude Dog
Old Apr 4, 2002 | 02:10 PM
discharge's Avatar
thanks
do you remember the conversion kit company....this came to me from searching ebay and seeing frames going for no more then 250 and A-arms not going more then 50 bucks......the frame is definately solid and strong, no bends, no breaks, the real reason i wanted to do this was so i could beef up the suspension but can't really find any j-arm kits....ahhhh maybe i am just wasteing my time
Old Apr 5, 2002 | 07:10 AM
b370's Avatar
discharge:
I have an 88 banshee that I did just what your talking about... I have been very pleased with the results. At the time I went through atvracing in Arizona for the kit and their upper a-arms (fully adjustable) Timmyboys is now doing a weld in kit also for a little less money. I have pics on my site when I installed the kit from atvracing. (see the link in my signature)
Here is the link for atvracing and here is the link for timmyboys
atvracing
timmyboys
Mp350
Old Apr 5, 2002 | 12:02 PM
seven's Avatar
I also did the conversion on a 89 banshee and it worked great. As long as you have some welding skills and comon sense its no problem.
Old Apr 5, 2002 | 12:12 PM
discharge's Avatar
so your saying i just weld this kit on and select whatever type of A-arm and shock combination i want right????
Old Apr 6, 2002 | 01:31 AM
seven's Avatar
Well it uses a stock top a arm from a 90 or newer banshee and normal banshee shocks. Takes about 30 minutes to weld it in place.
Njrider1230
Jul 29, 2023 05:16 AM
STLyamwar
Jul 25, 2020 04:44 AM
hueby
Aug 28, 2015 07:26 PM
DFWSRT8
Aug 20, 2015 09:24 AM
musselmark
Jul 17, 2015 02:40 PM
