My 650 started backfiring
Old Apr 4, 2002 | 06:54 PM
bigred650's Avatar
After i installed a twin air filter and took off the inspection cover it backfires when you let off the gas. Any ideas, does that mean it running lean?
Old Apr 4, 2002 | 07:52 PM
stebob's Avatar
You may need to turn your air mixture screw out a turn or 2. I recommend going in 1/2 turn increments however.
Old Apr 5, 2002 | 02:12 PM
trx450's Avatar
Backfires: too lean----out carb(s)/ too rich----out exhaust
Old Apr 5, 2002 | 02:46 PM
STAKK's Avatar
The stock air screw's are 2,1/4 turns out I have mine out 3 turns, thats what the dynojet kit recommends.
Old Apr 5, 2002 | 06:17 PM
Area51's Avatar
Did you just install the Twin Air filter, and then the problem started with no other changes, or did you re-jet also?
Old Apr 5, 2002 | 06:19 PM
Area51's Avatar
What inspection cover did you remove?
Old Apr 6, 2002 | 06:25 PM
bigred650's Avatar
I just installed the twin air filter my jet kit has no come in yet. The inspection cover is right below the handle bars were your pour the antifreeze in. It pulls in alot more air without it.
Hankey Pankey
26
Oct 18, 2020 03:50 PM
hunter1977
Ask the Editor
Jun 11, 2015 12:18 PM
generalpops
Jun 5, 2015 08:23 PM
generalpops
Jun 3, 2015 08:25 PM
1000gade
May 27, 2015 12:37 PM
