blaster wiring help needed!
Old Apr 4, 2002 | 10:34 PM
BiffBlaster's Avatar
well to make a long story short, brought the quad to a shop and they cut all sorts of wires.As of now I do not need the wires for the TORS system or the oil injector system, as well as the wires for the rear tail light. but i will need the wiring for the front light to work.So my question is what wires can i get rid of in this mess of wiring i have here and still be able to use my front light? I need to know what colors the wires are as well to help me remove them. Please someone help me out I'm in the process of a complete rebuild on the entire quad. thanks!
Old Apr 5, 2002 | 02:16 AM
bump
Old Apr 5, 2002 | 04:13 AM
THEMOOSE's Avatar
You are probably going to have to get a service manual. They have compleat wiring diagrams & you can get one for your blaster for around $30. It's a good investment!
Old Apr 6, 2002 | 01:58 AM
Blaster96's Avatar
Yes get a Service Manule by Clymar. I have done this to. If you lable ALL of the wire you know that will be a big help. You can strip the tape off of the harness and follow your unwanted wire and cut them. The grounds (black) will mostly go to a big connector in the harness, just cut this wire here. Find your TORS "computer box" under the hood and remove it from the electrical system folowing the previous procedure. Some of the wire will run directly from it to the switch on the carb. DO NOT cut any CDI or MAG. wires. I would suggest getting an electrical Schematic and study it before you do any cutting.
Why did your stealership cut your wires?
jrooker6
Ask the Editor
11
Apr 21, 2016 07:35 PM
jag6510
Jun 15, 2015 05:59 PM
clsharky
Jun 8, 2015 11:38 AM
wolfballa
Jun 5, 2015 01:38 PM
