diff. lube change
Old Apr 8, 2002 | 02:38 PM
raktrakr's Avatar
if i run mobil-1 synthetic gear lube in the front diff., will i need to add the limited-slip additive...'01 grizz
Old Apr 9, 2002 | 10:02 AM
95wolv's Avatar
If the 01 is like the other Yamaha limited slips, you will need to put in about 1.5 ounces of limited slip additive (get it at an auto parts store,comes in a little 4-5 ounce bottle.) I believe the newer ones use the lockable front end,activated from the handlebar,so they may not need it, but not being a Grizz owner,I can't be 100 % sure of that.
ultangler
Nov 30, 2024 01:35 AM
ReconBayou
Oct 31, 2022 05:37 PM
Sw00p
Sep 24, 2015 02:50 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
bmark0610
Sep 7, 2015 09:42 PM
