Premix on a banchee
Old Apr 9, 2002 | 11:31 AM
DrunkenNosMonkey's Avatar
What ratio do you guys think i should be running in my 97 Banchee
Old Apr 9, 2002 | 11:38 AM
Eq's Avatar
Eq
Whats a Banchee???
I run my Banshee at 32-1. Some of my buddies run 40-1. This is with Yamalube 2r
It all depends on what oil you are using. You should go by the manufactors suggested ratio.
Old Apr 9, 2002 | 11:40 AM
Manufacture recomends like 20:1 im using yamalube
Old Apr 9, 2002 | 08:29 PM
warrior350megamax's Avatar
you probably know this but the higher the ratio the less oil in the gas/motor so the less lubricated the motor is so the motor parts have a shorter life but you go a whole lot faster. 20:1 is the middle ratio i guess you could say. so the lower the ratio like 15:1 youre going to have a really lubricated engine but be real sluggish. and the higher the ratio like 40:1 a less lubricated engine but youll be a whole lot faster. but if you see oil coming out of your exhaust youve got to much oil. ive heard people up to 52:1 and a little higher so 32:1 is good. thats what i always ran when i had a 2 stroke. good luck!!
Cummins Driver
Sep 11, 2019 01:22 PM
Thor
Jul 19, 2002 05:00 AM
2stk4ever
Sep 14, 2001 12:41 AM
donpeter
Mar 25, 2001 06:58 PM
vernl
Jan 7, 2001 08:13 PM
