Coolant
Old Apr 10, 2002 | 03:40 PM
DSaholic's Avatar
I am going to change the coolant in the DS this weekend and I was wondering if it is safe to use the extended life 5/150 orange coolant in the DS ? Anyone have any ideas.....
Old Apr 10, 2002 | 07:19 PM
NewDSLover's Avatar
Don't know. About 4 mon ago I changed my clutch plates so I have to drain the fuilds. I used extended life coolant then. Haven't had a bit of problems yet. But I bet bomb says to use something different.
Old Apr 10, 2002 | 07:54 PM
Hightower's Avatar
The shop manual simply says to use 60/40 Glycol based coolant and water, period. They only warn not to use pure antifreeze because it does indeed freeze unless mixed with water.
I would imagine the orange is cool to use - I can't think of any components inside the DS engine of different material than any new car engine that uses it. My Silverado engine is all aluminum except the block, it uses it from factory.
I'd like to go orange too, 'cause it matches the color scheme better (seen thru the expansion tank).
Old Apr 11, 2002 | 03:30 AM
BlackHawk's Avatar
Another item you might consider is Engine Ice. (It's a nice Crystal Blue color.) I installed that and some radiator shrouds and my DS was signifigantly cooler! The first weekend out, I thought my fan may have died because it didn't come on until the very end of the first day! In previous trips the fan would come on during the first outing. I have a feeling the Engine Ice made more of an improvement than the shrouds, but I like the idea of both for added cooling.
Old Apr 11, 2002 | 01:25 PM
DSWOLF's Avatar
Blackhawk,where can i get some of that engine ice and how much did you mix it whit water.
DSWOLF...
1ArmBandit
55
Oct 14, 2015 09:03 PM
essonlaker
Sep 10, 2015 01:12 PM
Randy Lee Frye Sr.
Sep 9, 2015 02:30 PM
Kenidah
Sep 7, 2015 07:50 PM
