99 scrambler
Old Apr 10, 2002 | 11:01 PM
troyr's Avatar
How do I check the hub fluid or whatever is in them on the 99 4x4 scrambler?
Old Apr 11, 2002 | 09:36 AM
2000SCRMBLRMAN's Avatar
There is an allen key plug on the hub itself. You should take the plug out then turn the wheel until the plug hole is in the 4 O’clock or 8 O’clock position. If fluid starts coming out you are good. If not, add fluid slowly until it comes out. Use the Polaris hub fluid. Some people use automotive synthetic automatic trans fluid. If it hasn’t been changed you may want to just drain it all the way out and add new fluid
exmotocrosser
Sep 13, 2019 06:12 AM
Matt123
Sep 29, 2015 01:29 AM
exmotocrosser
Sep 26, 2015 08:18 AM
Nosparkpolaris
Sep 20, 2015 04:21 PM
1000gade
Sep 9, 2015 03:35 PM
