Snow trouble
Old Feb 28, 2000 | 10:49 AM
superduty1's Avatar
Ok Ive been reading other post such as honda,yamaha etc. I keep seeing people say that the Polaris want go or they have to pull them out.
Ive road mine in the snow aliebt it wasnt 2ft of snow but i never had a problem.So if you have had a problem please tell me or explain what they are talking about.
scott
Old Feb 28, 2000 | 11:03 AM
SWAC1's Avatar
I've had my SP500 in the snow since I bought it in December. I have only noticed belt slippage twice when driving fast in fresh powder. The vent for the clutch can allow powder snow to get inside causing the belt to slip. I got it out of the powder, and the slipping stopped after a few seconds. I am working on rerouting the ventilation tube inlet to prevent flying snow from getting sucked in. About getting stuck, the factory rubber has NO traction in the snow, and was so soft, would not hold ice screws in. Thus I pulled a few out, and caused a few leaks. I've upgraded to tires with deeper tread. The bi-claw and tri-claw combination should prevent me from ever getting stuck again.
Old Feb 28, 2000 | 11:32 AM
Tim1's Avatar
I know I do not know what they are talking about too.Once a bike hight-centers it's over you are stuck that is just a law of physic which dose not care what bike you ride.A hight ground clearance helps because it delays the hight-center so you go further before getting stuck.
Old Feb 28, 2000 | 11:37 AM
superduty1's Avatar
I agree and with the highest ground clearence in almost every class,there should not be a problem,unless you smoke a belt.
Old Feb 28, 2000 | 02:40 PM
Odin's Avatar
Put some panty hose material over the clutch exhaust outlet this will filter out snow dust.
Old Feb 28, 2000 | 07:06 PM
PolarisRacing's Avatar
Odin that is an good point-that is so simple but it should work
Old Feb 28, 2000 | 10:17 PM
atv_guy's Avatar
I was thinking of using a sponge foam dryer sheet
coated with air filter oil. That stuff is so
sticky I think it will keep water out too. But
I'm kind of lazy about it because I've never
had mine slip no matter how deep I went. If you
have to go through water over your knees then
you should GO AROUND IT! I think this would apply
to any ATV, if I want a submarine I'll save up and get one!
Old Mar 1, 2000 | 01:01 AM
JAY's Avatar
JAY
I have never had any trouble in the snow .I just wish we had more of it .
Do you know of any places around the omaha nebraska area that i could go to that have good amounts of snow .have fourwheeler will travel .
Old Mar 1, 2000 | 01:08 AM
Prospector's Avatar
Colorado!
Old Mar 1, 2000 | 02:25 AM
Jaime's Avatar
Odin put the panty hose over the intake of the clutch cover that works even better then the exhust i wish i could get stuck in snow this winter but it,s all gone now it,s muddin time
