What 250r components will fit a Cannondale??
Old Apr 17, 2002 | 08:31 PM
Sandgod's Avatar
Will A arms, front or rear shocks simply bolt right on?? I know the wheel bolt pattern is the same.....
Old Apr 17, 2002 | 08:49 PM
Mxracer98's Avatar
The offsets are different I put my mojave 18's which are 4/110 and they make the back-end 2 inches narrower.
Old Apr 17, 2002 | 09:41 PM
briansgi's Avatar
The 400EX a-arms will bolt up, so I'm assuming the shocks would as well. The offset on the wheels is different. If you put stock R wheels on a Cannondale, you will be 2" narrower. What is cool though is going the other way, I put stock Cannondale wheels on my R and it's stance is wider now without buying a $350 aftermarket axle to achieve the same results. Of course I bought the axle anyway but.....
Old Apr 17, 2002 | 10:15 PM
Sandgod's Avatar
Thanks... I should of specified aftermarket parts. Stock 250r parts on a Cannondale..NOT. If 400ex A arms will the aftermarket shocks should???
Old Apr 17, 2002 | 10:23 PM
Mxracer98's Avatar
So you could bolt on aftermarket a-arms from 400ex's and stuff. and everything will remain the same?
Old Apr 17, 2002 | 10:28 PM
briansgi's Avatar
The 400EX a-arms will bolt up but I would not buy aftermarket a-arms specifically for the 400EX and then use them on the Cannondale. Supposedly the geometry is not correct. I know what you are getting at. You can buy the aftermarket parts for a 400EX cheaper than for the Cannondales so why not use them if they will work. The reason I know the a-arms for a 400EX will work on a Cannondale is I have a friend who is a pro rider who borrowed my FX400 and installed just such a-arms, they bolted up just fine.
Old Apr 17, 2002 | 10:29 PM
YoDaddy's Avatar
Carey told me that it would work BUT it wouldn't fit quite like they should which would affect the handling. He STRONGLY suggested that I don't try it.
Alex Rodak
Sep 13, 2015 12:30 AM
Nosniborpapa
Sep 12, 2015 05:54 PM
Alex Rodak
Sep 12, 2015 09:39 AM
Alex Rodak
Sep 11, 2015 11:42 PM
MrTrashMan2U
1) Engine problems..
Sep 9, 2015 11:11 AM
