Best 300ex mods
Old Apr 18, 2002 | 08:05 PM
HondaGuy300EX's Avatar
What is the best mods for a 300ex is there any under 100$$
Old Apr 18, 2002 | 08:40 PM
ATVer14's Avatar
Remove your airbox lid, get either an UNI air filter if you ride in dusty conditions, or a K&N if you ride in not so dusty conditions, remove your choke from the carb, re-jet the carb (or buy a jet kit), and maybe get a set of different handlebars (the stock ones are easily bent and don't have that great of a feel to them.)
Old Apr 18, 2002 | 08:43 PM
ATVer14's Avatar
Also check out my website for reviews on most of the products I have for my 300EX. It's still in the works, but most of the reviews are up there now.
Old Apr 19, 2002 | 12:16 PM
YZGUY's Avatar
TIRES, if you have not done that already. Get rid of those stupid balooney stock tires. I like Holeshots myself, but I ride in the desert.
Old Apr 20, 2002 | 02:33 AM
RiverRat440's Avatar
re-jet re-jet re-jet,, i cant say that enough... remove the airbox lid, buy a d7 plug (stock is d8, the d7 will burn hotter), buy a K&N air filter, a good pipe, or moddify the stock one if you wanna go really cheap, rejet the carb, you can jet WAY past the stock numbers with this set up, i had this same setup with a DG RCM pipe, and i was running a 152 jet, stock they come out with like a 122 or 128. then, after you get some more money, deffinintantly go for tires, the knobbies suck,, i like 20 inch fast trekkers myself, but they wear fast, but they are very cheap, 40 bucks a pop,and they hook up, but still let you slide out of a corner
Old Apr 20, 2002 | 07:17 PM
Mitteer's Avatar
Rejet but I would stay with the stock spark plug. They run hot enough as it is. However if you do go with the hotter plug definetely put a big jet in.
Old Apr 20, 2002 | 07:52 PM
they are hot enough, but with a hotter one, you can run a bigger jet, meaning more gas to the cylinder, meaning more power.
Old Apr 21, 2002 | 10:12 PM
Mitteer's Avatar
And also meaning more heat and wear to the engine.
Old Apr 21, 2002 | 10:37 PM
that is very true, but a bore kit does the same, puts more heat on the cylinder, and they are reliable, unless of course you put a 450 kit into a 300ex. but you have a point,, the biggest reason i went ahead and ran it in my 300ex is because i was gettin ready to install a 352 kit anyway
Old Apr 28, 2002 | 01:27 AM
mxracer08's Avatar
Wiseco 11:1 piston, White bro's race cam and valve springs, port and polish the head, Uni Filter, Curtis Sparks Exhaust, AC Bumper and Nerfs, TAG handlebars, Pro-design kill switch, Laeger +2 aarms, PEP shocks, Lonestar +4 axle, and Holeshot MX's on Douglas .190's
Customer Service #1
May 15, 2020 08:46 AM
Sep 23, 2015 06:23 AM
Bonzhonda300ex
TheATVSuperStore
Sep 17, 2015 01:21 PM
PrairieDog126
Sep 16, 2015 01:33 PM
1ArmBandit
Sep 8, 2015 08:59 PM
