Gonna Build a 250r from the frame up; a few questions.
Old Apr 21, 2002 | 06:22 PM
250rampage's Avatar
I've always wanted an 'R, so now I'm gonna bite the bullet and get one, just a bit different than most people do. First, i'm going to get a trx frame in good shape, and an 85-86 ATC250r, and go from there. I'm aware of the work this requires, but this way, I know how it was done. So, I have a few questions first;
1) I seem to remeber reading somewhere that the 85-86 ATC rear end (swingarm back, including shock) can be used in a trx frame. Is this right?
2) Will the intake/carb boot/airbox off of an ATC work in the TRX frame?
3) If I use the 85-86 motor, I have to use the 86 frame because of the rear engine mount, correct?
I know I'll think of more before I even start this, but that's all I can think of off hand....
Old Apr 21, 2002 | 06:57 PM
Ohio250rlover's Avatar
well i can help you out frist off all the water cooled atc/trx engines are the same as far as how they bolt up and most other ways also as far as the carb and intake boot i also happen to know for a fact will be alright i ran my 86 atc 250r engine in my trx250r for like 8 months,the swing arm will also work my info isn't hear say or what blow joe down the road told me iv done it i have my trx all the way apart and my dad is trying to find someone to weld a few cracks right now so i to will be building a 250r soon hehe, dude if u have yahoo messger im "ohiowoodsrider250r" and im happy to help in any way i can good luck
Old Apr 21, 2002 | 06:59 PM
250rampage's Avatar
I'd heard that the the whole rear end bolts up....
Old Apr 21, 2002 | 07:10 PM
it will with the trx carrier other wise with calpier mounting you'll need one from the atc to make it work
Old Apr 21, 2002 | 07:18 PM
250rampage's Avatar
I was just planning on using the caliper and master cylinder from the ATC. I'm going to buy a complete ATC.
Old Apr 21, 2002 | 07:21 PM
ahhh i see that'll work hey do have yahoo messger?
Old Apr 21, 2002 | 07:28 PM
250rampage's Avatar
No, but I have ICQ and AIM
ICQ# is 22760453
AIM is BrockZurcher
Old Apr 21, 2002 | 07:43 PM
ok i added you on aim im insanequadpilot
Old Apr 21, 2002 | 07:58 PM
retro's Avatar
Get the 86 ATC, it has more usable parts to swap.
If you are going to race or anything I would do it right the first time. Don't get a stock frame or anything that you will need to replace again!
ERIC
Old Apr 21, 2002 | 08:16 PM
250rampage's Avatar
Is there a big difference between the 85 and 86 ATC? I always thought they were nearly identicle. I'm not planning on doing any serious racing with it , maybe go to open practice with it a few times, but my 400 is my race bike. Do you guy's think I should get an ATC for parts, or I should go and buy everything seperate. The ATC seems like the better option to me, but give me your thoughts.
