what are the best 400EX shocks
Old Feb 29, 2000 | 10:12 PM
TL1000R's Avatar
Hey everyone, this is the first time I have posted a question. I bought a 99 400ex about 3 weeks ago. I have primarily bought this Quad to race in the local (Arkansas)hare scrambles. I love the bike, after I only rode it one time before I raced it and cleaned up in the AM's and beat every pro but one. What I have found to be my biggest problem is that the shocks don't work well enough and it needs a steering damper. I am 6'5 and 220lbs so I do tend to put a strain on the bike. What I would like from you guys is some honest (from experience) suggestions on what steering damper and shocks to look at, price is a consideration also. I have been looking at the Works Triple Rate springs.
Thanks guys
Old Mar 1, 2000 | 04:34 PM
hot_shoe_cv's Avatar
Well, you are probably going to get a bunch of opinions on this so keep in mind that they are just that..opinions.I's suggest that you make use of the search button & do a search under suspension, or simply shocks. You'll find more info that you ever would need.
In my case I'm running TCS shocks on my Warrior from CTRacing & I find them excellent for desert & XC. I also use a damper from PEP. It has three adjustment settings which more than cover anything I run across. In fact I've settled on the center adjustment fo all round use.You might think about some after market bars also to relieve arm pump & upperbody fatigue on long loops. a good set af aluminum bars will be an excellent addition to new shocks & steering damper.
If you should decide to go with CTS, (CTRacing.com)
the guys at CT will do a profile on you as to your weight, riding style, & skill level in order to set up the shocks specifcally for you. It's best not to over state your skill level as it could result in the wrong valving and/or spring rates. They also will do a free revalving within 30 days if you aren't satisfied.
BTW, the PEP dampener is about $90 & the TCS's are $650. Not cheap, but way less than some.
XxS0ccerstarxX
Sep 24, 2015 11:53 PM
cboler9
Sep 24, 2015 08:35 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
