Pro Design Pro Flow or K&N?????
Old Apr 28, 2002 | 11:36 AM
warrior350megamax's Avatar
i have a 93 warrior, what air filter would be the best to get? positives...negatives
Old Apr 28, 2002 | 11:45 AM
garyc660R's Avatar
The K and N will flow slightly more air, but the compromise is less filtering capability. So if you don't ride in dusty conditions, the K and N would do fine. You need the pro-flo either way....your stock air box set up will allow dust inside your engine leading to premature engine failure.
Old Apr 28, 2002 | 12:10 PM
95wolv's Avatar
I just picked up a Twin Air filter adapter for my Wolverine,which is the same air box as your Warrior. I got mine from Dennis Kirk for 79 bucks, now I just saw it the the 2002 Rocky Mt. ATV catalog for 69 ! The cheapest I've seen the Pro Flow is 85,and the Twin Air is a solid aluminum flange,and the 2 stage filter that comes with it is HUGE !! I can't wait to put it on and see how it looks,has to be a lot better than smearing a load of grease on a foam seal!! As I have just overhauled my engine,I'm not ready for a bad seal to let dirt into my investment. Check around,but I doubt you can get one cheaper than what I saw in the catalog.
Old Apr 28, 2002 | 04:02 PM
A2000's Avatar
I have the foam kit because I run in dusty conditions most of the time. If you're running on hardpack or trails use the K&N.
Old Apr 28, 2002 | 04:47 PM
AZSAND's Avatar
THAT!!!!!Sounds down right sexy!
i run the k&ns on all my other bikes but for the warrior foam filters work better and if you go with a two stage make sure when installing it to ad silicone to the oring seal so it dosen't roll on installation and allow sand in.good luck!!!
Old Apr 29, 2002 | 12:35 AM
swifty's Avatar
Go with the Pro-Flow and the Foam filter [img]i/expressions/face-icon-small-happy.gif[/img] , the k&n works good on the street, but in the dirt, you motor will "EAT DIRT" [img]i/expressions/face-icon-small-mad.gif[/img]
Old Apr 29, 2002 | 08:29 AM
i decided to get a K&N since all i really do is ride on hard packed trails and gravel and grass. should the K&N work good?
Old Apr 29, 2002 | 09:19 AM
garyc660R's Avatar
Keep an eye on your plug too make sure you don't lean your engine.......
Old Apr 29, 2002 | 11:33 PM
Warrior400boy's Avatar
K&N
Old Apr 30, 2002 | 08:01 AM
guardog's Avatar
go with the pro design. I have the K&N and I'm not really impressed. I would have preferred the clamp on style
