Magura Hydraulic Clutch Assembly worth the money?
Should I get a Magura hydraulic clutch lever assembly for my Banshee? Are there any drawbacks or durability issues that I should be concerned about? I also would appreciate hearing any positive feedback you may have.
What about other brands such as Billetanium? I need to do something with my worn out clutch lever/lever housing. I thought about getting the Magura before we head to Little Sahara next month.
Thanks in advance.
Daren
420 Banshee
CBR 929 For Sale
Thanks in advance.
Daren
420 Banshee
CBR 929 For Sale
I have a magura clutch on my cannibal and its the best. My friends all want to have it, and my hand doesnt ever get tired because the pull is like nothing. Though I hear that you have to replace the oil in it every so often.
If your talking the complete hydraulic clutch system (not just the lever) the Magura slave cylinder has a bike spoke as a pull rod that is connected to the clutch release arm. This looks weak to me. The Billetanium system uses a hex adapter (about 10 times thicker than a spoke).
Check out the BILLETANIUM WRITE-UP HERE.
Yes, I was referring to the entire system. I appreciate all of the information. The Billetanium was tried on a 250R, do they have a setup for the Banshee too? Will it work with bigger carbs without any interference? Thanks again.
Daren
Daren
