Brake adjustment
Old Apr 29, 2002 | 02:27 AM
curt234's Avatar
The foot brake on my honda fourman 450s is sticking and staying down. U have to lift the brake petal with your hand back up so it doesn't stick. Is it time for new brakes or what?
Old Apr 29, 2002 | 03:09 AM
KNOWSALOT's Avatar
The Facility
First of all, check the return spring on thew brake pedal to see if it has been stretched.
You could be in need of new brakes. When the brake shoes get worn to a certain point, the "cam" that operates the brake shoes turns so much that it actually hangs up.
You could also just have glazed brake shoes. What you need to do is jack up the rear and take the brake drum off and then push your pedal. See if it still hangs up with the brake drum removed from the quad. If your brake shoes are glazed, just rub them down with some sandpaper and do the same with the brake drum.
Old Apr 29, 2002 | 10:44 PM
curt234's Avatar
Found out what it was the brake petal where the shaft slips on to the frame was rusty and binding up. Cleaned it up and greased it and works good know. Thanks for the post.
STLyamwar
Jul 25, 2020 04:44 AM
mattcraig1
Aug 19, 2015 03:48 PM
Stirling
Aug 9, 2015 01:49 PM
SixSpeed5
8
Aug 2, 2015 05:38 PM
willday08111217@gmail.com
Technical and How-To Articles
Aug 1, 2015 04:05 AM
