AIR FILTERS??
Old Apr 30, 2002 | 11:51 AM
PORKY's Avatar
HEY WHAT IS THE BEST STUFF TO SPRAY ON THAT FOAM FILTER WRAP?? THE FACTORY STUFF IS REALLY TACKY.
ANY SUGGESTIONS WOULD BE GREAT. USUALLY RIDE IN ALOT OF DUSTY AREAS.
Old May 1, 2002 | 01:00 AM
kindsambo's Avatar
After I clean my air filters and dry them, I just soak them good with motor oil and make sure I wring them out good and vola...all done.
Old May 1, 2002 | 08:37 AM
delta's Avatar
Tacky is what you want! I bought some spray-on stuff from PJ1. It is very tacky, just like the factory stuff. Motor oil will eventually drain to the bottom of the filter, leaving the bulk of it untreated. But it IS better than nothing. You may be better off with one of the 'pre-filter' sock-type things, which are good for extreme dust.
Old May 1, 2002 | 06:22 PM
minehunter's Avatar
Not only will it eventually go to the bottom of the filter, it will also cause the foam to decay over time. The stickier the better.
Old May 1, 2002 | 06:39 PM
TG1's Avatar
TG1
I've been using Honda filter oil. So far I have complains (it was the only stuff on the self at the Non-Cat dealer). As long as the oil sticks the filter to trap all the dust and other crap it ok by me.
Old May 18, 2004 | 05:59 PM
Stevehondarocks's Avatar
Default AIR FILTERS??
what is the best way to clean off the realy tacky oil?
Old May 18, 2004 | 06:57 PM
doober's Avatar
I bought a K&N filter cleaner kit, works good for me, 14$ or something like that, comes with a cleaner and the oil.
Old May 19, 2004 | 03:22 AM
FlyingMan's Avatar
I mottocross and i use Bel-Ray foam filter oil, very good stuff, a little pricey but cheaper than an engine.
Old May 19, 2004 | 03:06 PM
GreatCanadian's Avatar
I have a Rancher 350 with a foam air filter.. my manual recommends gear oil SAE 80-90
cswiger
Polaris Side by Sides
12
Oct 5, 2015 03:34 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
Steeldon
Sep 9, 2015 09:38 AM
black798
Sep 9, 2015 07:42 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
