250r wont start
Old May 2, 2002 | 09:17 PM
XCLonestar250r's Avatar
i just rebuilt my motor and i go to kick it over and no spark... i checked the ground and thats good..ignition coil checked good...still nothing..i've heard that the 250r's are known for spark problems but dont know how much of that is true.. any help would be thankful
Old May 2, 2002 | 10:39 PM
87250r88's Avatar
Check your kill switch , if in doubt unhook it. I know this sounds simple , but sometimes we overlook the obvious.
Old May 2, 2002 | 10:42 PM
thats the thing i dont have anything to kill the motor other than holding the brake and killin the motor that way.. i just bought a kill switch but i want to see spark before i hook it up.
Old May 3, 2002 | 10:01 AM
briansgi's Avatar
Did you replace or check the cdi box? I noticed you have another R, swap the cdi box and see if that solves the spark problem. I switched to the CR250 electronics, much more reliable but a bit pricey!! Also, the spark plug boot sometimes will have a poor connection causing this problem. How did you check the coil and what were your readings? The primary coil should be between 0.1 - 0.3 ohms, secondary coil should be between 7,400 - 11,000 ohms with plug wire attached. With plug wire disconnected, the secondary coil resistance should be between 3,700 - 4,500 ohms. Make sure you have a good quality volt meter and a fresh battery when making these checks.
Old May 3, 2002 | 06:36 PM
lonestarbanshee's Avatar
briansgi is right. If you have another 250R that you could swap some parts on, the cause will be easy to find. If your CDI is stock, it probably has went out. They're not expensive. I rebuilt my motor as well, and it wouldn't get a very good spark, but with a new plug and a different coil, it fired right up.
joe blo2
Jun 7, 2015 10:54 AM
1000gade
May 27, 2015 12:37 PM
bigg_fatt_monn
Jun 16, 2000 09:41 PM
rking85
May 20, 2000 11:01 PM
250rCanCan
Aug 17, 1999 11:58 PM
